[gdal-dev] ogr2ogr for windows
jratike80
jukka.rahkonen at maanmittauslaitos.fi
Fri Oct 18 03:49:36 PDT 2019
You may be behind a proxy server and you must use the Advanced Install
altertative which shows you a box to feed the proxy url. However, you can't
install driver https://gdal.org/drivers/vector/filegdb.html with OSGeo4W.
Perhaps it is due to license requirements because that driver requires File
GDB API SDK from ESRI
http://appsforms.esri.com/products/download/#File_Geodatabase_API_1.3.
The other driver that you wished comes with the OSGeo4W and also with the
binaries from gisinternals.com
ogrinfo --formats |find "FAA"
AeronavFAA -vector- (rov): Aeronav FAA
It may be that you need to hire somebody to make you a special Windows build
with the ESRI fgdb. I have managed to do that through this mailing list
sometimes and at reasonable price.
-Jukka Rahkonen-
paul.malm wrote
> Thanks,
> I tried that but nothing happens when I execute the installation file. I
> don’t get any connection And a empty list appears where I can add new
> URLs?
> Kind regards,
> Paul
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
