[gdal-dev] ogr2ogr for windows
Stephen Knox stephenknox73 at gmail.com
Fri Oct 18 04:46:41 PDT 2019
I think you can install the ESRI FileGDB from OSGeo4W:
http://download.osgeo.org/osgeo4w/x86/versions.html - see gdal-filegdb
On Fri, Oct 18, 2019 at 11:49 AM jratike80 <
jukka.rahkonen at maanmittauslaitos.fi> wrote:
> Hi,
> You may be behind a proxy server and you must use the Advanced Install
> altertative which shows you a box to feed the proxy url. However, you can't
> install driver https://gdal.org/drivers/vector/filegdb.html with OSGeo4W.
> Perhaps it is due to license requirements because that driver requires File
> GDB API SDK from ESRI
> http://appsforms.esri.com/products/download/#File_Geodatabase_API_1.3.
> The other driver that you wished comes with the OSGeo4W and also with the
> binaries from gisinternals.com
> ogrinfo --formats |find "FAA"
>   AeronavFAA -vector- (rov): Aeronav FAA
> It may be that you need to hire somebody to make you a special Windows
> build
> with the ESRI fgdb. I have managed to do that through this mailing list
> sometimes and at reasonable price.
> -Jukka Rahkonen-
> paul.malm wrote
> > Thanks,
> > I tried that but nothing happens when I execute the installation file. I
> > don’t get any connection And a empty list appears where I can add new
> > URLs?
> > Kind regards,
> > Paul
> Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20191018/6a4b2e13/attachment.html>
