[gdal-dev] ogr2ogr for windows
Rahkonen Jukka (MML) jukka.rahkonen at maanmittauslaitos.fi
Fri Oct 18 05:02:40 PDT 2019
Thanks Stephen,
You are right, it is available in OSGeo4W and installs nicely
  ogrinfo --formats |find "GDB"
  FileGDB -vector- (rw+): ESRI FileGDB
  OpenFileGDB -vector- (rov): ESRI FileGDB
-Jukka-
Lähettäjä: Stephen Knox <stephenknox73 at gmail.com>
Lähetetty: perjantai 18. lokakuuta 2019 14.47
Vastaanottaja: Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi>
Kopio: gdal-dev at lists.osgeo.org
Aihe: Re: [gdal-dev] ogr2ogr for windows
I think you can install the ESRI FileGDB from OSGeo4W:
http://download.osgeo.org/osgeo4w/x86/versions.html - see gdal-filegdb
On Fri, Oct 18, 2019 at 11:49 AM jratike80 <jukka.rahkonen at maanmittauslaitos.fi<mailto:jukka.rahkonen at maanmittauslaitos.fi>> wrote:
You may be behind a proxy server and you must use the Advanced Install
altertative which shows you a box to feed the proxy url. However, you can't
install driver https://gdal.org/drivers/vector/filegdb.html with OSGeo4W.
Perhaps it is due to license requirements because that driver requires File
GDB API SDK from ESRI
http://appsforms.esri.com/products/download/#File_Geodatabase_API_1.3.
The other driver that you wished comes with the OSGeo4W and also with the
binaries from gisinternals.com<http://gisinternals.com>
ogrinfo --formats |find "FAA"
  AeronavFAA -vector- (rov): Aeronav FAA
It may be that you need to hire somebody to make you a special Windows build
with the ESRI fgdb. I have managed to do that through this mailing list
sometimes and at reasonable price.
-Jukka Rahkonen-
paul.malm wrote
> Thanks,
> I tried that but nothing happens when I execute the installation file. I
> don’t get any connection And a empty list appears where I can add new
> URLs?
> Kind regards,
> Paul
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
gdal-dev mailing list
gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20191018/ef2cd76d/attachment.html>
