[gdal-dev] converting AAIGrid to SRTM
Even Rouault
even.rouault at spatialys.com
Wed Oct 23 12:43:47 PDT 2019
> Question 1:
> Is there a way to have it auto name the output file? I'd assume if it knows
> what it's suppose to be named, there should be a flag to automatically name
> it that. I can't find that, and need it to convert several thousand of
> these files.
Such an option doesn't exist, but it shouldn't be hard to implement if you
want to submit a pull request for that. I'd suggest to trigger that mode if
the output filename provided is actually a directory name ("." being a valid
name).
> Question 2:
> Is my re-tiling correct and method correct to convert to SRTM 3 arc second
> HGT files?
Looks good
Even
http://www.spatialys.com
