[gdal-dev] converting AAIGrid to SRTM
Bryan Fields
Bryan at bryanfields.net
Tue Oct 22 17:03:30 PDT 2019
Greetings,
I have a need for corrected version 4 of the 3 arc second SRTM data. This is
only available as a AAIGrid format for some reason, not SRTM HGT.
I've pulled the 30x30 degree tiles from here in AAIGrid:
http://srtm.csi.cgiar.org/srtmdata/
gdal_translate requires the input file to match the resolution of the SRTM
output, which is 1201 x 1201 with 1 overlap pixel.
So I broke the 30x30 into 1201 x 1201 AAIGrid files first:
gdal_retile.py -of AAIGrid -v -ps 1201 1201 -overlap 1 -v -csv csv.csv
-targetDir out cut_n00w090.asc
Then to the out/ directory, and use gdal_translate:
gdal_translate -of SRTMHGT cut_n00w090_01_01.asc output.hgt
This appears to work and gives a warning of:
Warning 1: Expected output filename is N29W090.HGT
Question 1:
Is there a way to have it auto name the output file? I'd assume if it knows
what it's suppose to be named, there should be a flag to automatically name it
that. I can't find that, and need it to convert several thousand of these files.
Question 2:
Is my re-tiling correct and method correct to convert to SRTM 3 arc second HGT
files?
Is there a better way to do any of this? I did search the archives and was
unable to find much else as the SRTM doesn't look that popular of a format to
process.
Bryan Fields
727-409-1194 - Voice
http://bryanfields.net
