[gdal-dev] FileGDB create layer error
Jon Morris
Jon.Morris at jbarisk.com
Fri Oct 25 01:19:54 PDT 2019
Hi All,
I came across an intermittent system test failure and just wanted to clarify what was going on.
While trying to add a layer to a newly-created File GDB, we got the error message: Failed at creating table for \expected_dem_mods_germany (General function failure.).
Turning on GDAL debugging gave the message:
FGDB: Did not found a match in ESRI SRS DB for layer SRS. Using morphed SRS WKT.
Failure is to be expected
The XML output below included this element:
<WKT>PROJCS["Lambert_Azimuthal_Equal_Area",GEOGCS["GCS_GRS 1980(IUGG
, 1980)",DATUM["D_unknown",SPHEROID["GRS80",6378137,298.257222101]],PRIMEM["Gree
nwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Lambert_Azimuthal_Equ
al_Area"],PARAMETER["latitude_of_origin",52],PARAMETER["central_meridian",10],PA
RAMETER["false_easting",4321000],PARAMETER["false_northing",3210000],UNIT["Meter
",1]]</WKT>
So, question 1: is this failure because the SRS is not in the Esri list of expected coordinate systems? It would not surprise me, because this is a test created from bad user data, where the SRS does not match the one they usually use.
However, question 2: why does it not fail every time? The only place we have seen this error is during a conda build on our CI server, when using Python 2. When we run tests on our local machines, or use our tool on Python 3, the layer is created OK. I want to be sure that users are not going to encounter this error, and that our tool is able to handle their data.
Thanks,
Jon
Jon Morris
Software Developer
Skype<sip:jon.morris at jbarisk.com>
T +44 (0) 1756 799919
www.jbarisk.com<http://www.jbarisk.com>
[Visit our website]<http://www.jbarisk.com> [http://www.jbagroup.co.uk/imgstore/JBA-Email-Sig-Icons-LINKEDIN.png] <https://www.linkedin.com/in/jon-morris-a2897b4/> [Follow us on Twitter] <https://twitter.com/jbarisk>
We've moved!
Our new postal address and registered office is JBA Risk Management Limited, 1 Broughton Park, Old Lane North, Broughton, Skipton, North Yorkshire BD23 3FD.
No changes to our telephone numbers or e-mail addresses.
Find out more about us here: www.jbarisk.com<http://www.jbarisk.com/> and follow us on Twitter @JBARisk<http://twitter.com/JBARisk> and LinkedIn<https://www.linkedin.com/company/2370847?trk=tyah&trkInfo=clickedVertical%3Acompany%2CclickedEntityId%3A2370847%2Cidx%3A2-1-2%2CtarId%3A1447414259786%2Ctas%3AJBA%20RISK%20MANAGEMENT>
The JBA Group supports the JBA Trust.
All JBA Risk Management's email messages contain confidential information and are intended only for the individual(s) named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.
Please notify the sender immediately by email if you have received this email by mistake and delete this email from your system.
JBA Risk Management Limited is registered in England, company number 07732946, 1 Broughton Park, Old Lane North, Broughton, Skipton, North Yorkshire, BD23 3FD, Telephone: +441756799919
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20191025/92d5c23f/attachment.html>
