[gdal-dev] Ogr2ogr: export attribute data (columns row data) from PostGis to DXF
Bojan Bizjak
bojan.bizjak at mastersoft.net
Fri Oct 25 01:38:12 PDT 2019
I can export multiple layers to sigle Dxf file without no problem using
SQL.
My question is how could attributbe data be entered into these layers using
SQL.
We are thinking in this direction that BlockAttributes should be filled and
the DXF_INLINE_BLOCKS option must be set to false.
Best regards,
Bojan Bizjak
[image: cid:image001.png at 01D4DDC4.83B4CDE0]
[image: cid:image002.png at 01D4DDC4.83B4CDE0]
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20191025/4563f38e/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20191025/4563f38e/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20191025/4563f38e/attachment-0003.png>
