[gdal-dev] add gdal package to C
Marsh, Chris chris.marsh at usask.ca
Mon Oct 28 09:55:46 PDT 2019
As Mateusz said, impossible to help without knowing your environment. I do not wish to turn this into a long email chain helping you compile against a static library as that's not what this list is for.
however, gdal is linked against link any other static library.
For example:
https://www3.ntu.edu.sg/home/ehchua/programming/cpp/gcc_make.html#zz-1.8
For how to link against a static library and set the include path. If you really end up stuck, go take a look at StackOverflow, there are others asking similar questions there. Good luck!
Cheers
Chris
On Mon, Oct 28, 2019 at 12:46 AM Mateusz Loskot <mateusz at loskot.net<mailto:mateusz at loskot.net>> wrote:
CAUTION: This email originated from outside of the University of Saskatchewan. Do not click links or open attachments unless you recognize the sender and know the content is safe. If in doubt, please forward suspicious emails to phishing at usask.ca<mailto:phishing at usask.ca>
On Mon, 28 Oct 2019, 01:00 rachmat maulana, <maularachmat at gmail.com<mailto:maularachmat at gmail.com>> wrote:
Hello,
I read the documentation and see there are C/C++ API for gdal,
How do I add gdal package to my compiler? (when I run "#include <gdal.h>" it gives me an error)
This is generic question how to use C++ compiler toolkit.
I usually use python, but my professor ask me to use C/C++,
Ask your professor for help.
I know only a little bit of C/C++, please help
This list does not offer help about using compilers.
You will need to read documentation of your compiler.
Mateusz Loskot, mateusz at loskot.net<mailto:mateusz at loskot.net>
(Sent from mobile, may suffer from top-posting)
gdal-dev mailing list
gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20191028/17741ab2/attachment-0001.html>
