[gdal-dev] Limit on the number of files for gdalbuildvrt
Jose Gomez-Dans
jgomezdans at gmail.com
Wed Oct 30 08:52:54 PDT 2019
I'm mosaicking a large number of small tiles using the GDAL python bindings
(python 3.7, gdal 3.0.1, but also tested on 2.4.2). Code is something like
*output_fname = "/something/or/other.vrt"*
*fnames = ["file1.tif", ..., "fileN.tif"]*
*dst_ds = gdal.BuildVRT( output_fname, fnames,
options=gdal.BuildVRTOptions(separate=True), )*
*dst_ds = None*
This fails with lots of errors like
ERROR 4: fileXXX.tif: No such file or directory
Warning 1: Can't open fileXXX.tif. Skipping it
The files are available on disk, and gdalinfo identifies them with no
issues.
Piping the files on a text file and using gdalbuildvrt results in the same
issue. The overall effect is that no information goes into the mosaic.
This approach works well when I tested with a handful of files (e.g. 4),
but I am now mosaicking a large number of files (>1000), and I was
wondering whether this could be an issue due to limits on opened files and
so on? This is on Linux.
The aim of this is to create a VRT mosaic that can then be converted to
GeoTIFF.
Any pointers?
many thanks
Jose
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20191030/25187087/attachment.html>
