[gdal-dev] GDALClose()...
Even Rouault
even.rouault at spatialys.com
Wed Oct 30 01:42:22 PDT 2019
On mercredi 30 octobre 2019 00:49:24 CET TUELLER, SHAYNE R CIV USAF AFMC 519
SMXS/MXDEC wrote:
> All,
> We're currently using GDAL 2.3.1 on Windows to develop a shapefile editor
> for our application.
> We're seeing a crash in our application when we call GDALClose() on a
> dataset/layer that contains a large shapefile with a large number of
> polygons. We opened the shapefile and set the dataset by calling
> GDALOpenEx(...).
> When we comment out the GDALClose() call, the application closes the
> dataset/layer without a crash.
> My question is, if we ignore calling GDALClose() to close a layer/dataset,
> will this create a memory leak in our application?
Yes, and if you did changes to the shapefile (as you mention "editor"), then
the shapefile header will not be updated.
I'd suspect there is a misuse of the GDAL API on your side or some other
memory corruption. Hard to tell what exactly with just what you mentionned.
Even
http://www.spatialys.com
