[gdal-dev] ogr2ogr shp
paul.malm at lfv.se paul.malm at lfv.se
Wed Sep 4 06:04:45 PDT 2019
When I import a shape layer to a postgis db with ogr2ogr, the table-name  only gets lower characters (railroads) even though the shapefile is named like RailRoads.shp. Is there a way to force the parser to use the same characters as the filename
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190904/3f5e021d/attachment.html>
