[gdal-dev] CURL error - SSL certificate problem
Pedro Venâncio pedrongvenancio at gmail.com
Mon Sep 9 15:41:35 PDT 2019
Hi Tobias,
Disabling https check, it works!
Testing in a Linux environment, with GDAL 2.2.2, I don't have the https
issue, so I assume that the SSL certificates are only checked in versions >
2.2.2, correct?
About the object key for Google Cloud Storage, anyone have an idea?
Thank you very much!
Best regards,
Pedro
Tobias Wendorff <tobias.wendorff at tu-dortmund.de> escreveu no dia segunda,
9/09/2019 à(s) 17:47:
> Am Mo, 9.09.2019, 18:37 schrieb Pedro Venâncio:
> > Any hint about this issue?
> Please try to add "--config GDAL_HTTP_UNSAFESSL YES".
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190909/5f5ca677/attachment.html>
