[gdal-dev] Bogus GeoJSON file or am I doing something wrong? (re-post)
Simon Eves
simon.eves at omnisci.com
Wed Sep 25 08:47:04 PDT 2019
I concur.
That said, I'm sure I have come across GeoJSON files with the
integer/scale/offset encoding before. I figured that was a standard thing,
but your response suggests otherwise.
That also said, I am digging through our stash of test files and I can't
find any like that, so maybe I'm dreaming.
Some Googling seems to indicate that the "hc-transform" node might be
something from HighCharts... starting here
https://github.com/highcharts/highcharts/issues/7960
I'll let you know if I find anything more...
SE
On Wed, Sep 25, 2019 at 8:35 AM Even Rouault <even.rouault at spatialys.com>
wrote:
> On mercredi 25 septembre 2019 08:27:56 CEST Simon Eves wrote:
> > OK, so it's a weird file.
> > I'll leave it to you to decide whether it's worth making GDAL/Proj deal
> > with it. I suspect not, and that's fine with us.
> Would only be a GDAL only thing.
> One single occurrence of such a file doesn't seem to be a very compelling
> case.
> Spatialys - Geospatial professional services
> http://www.spatialys.com
<http://www.omnisci.com/>
Simon Eves
Senior Graphics Engineer, Rendering Group
OmniSci, 1 Front St. #2650, San Francisco, CA 94111, USA
Email: simon.eves at omnisci.com | Cell: 415.902.1996
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190925/393d1ce7/attachment.html>
