[gdal-dev] Bogus GeoJSON file or am I doing something wrong? (re-post)
Simon Eves
simon.eves at omnisci.com
Thu Sep 26 08:41:38 PDT 2019
To wrap this up, I got in touch with HighCharts, and they confirmed that
this file is from them, but not a real GeoJSON, and not expected to be
usable outside their software ecosystem.
Thanks again.
SE
On Wed, Sep 25, 2019 at 8:47 AM Simon Eves <simon.eves at omnisci.com> wrote:
> I concur.
> That said, I'm sure I have come across GeoJSON files with the
> integer/scale/offset encoding before. I figured that was a standard thing,
> but your response suggests otherwise.
> That also said, I am digging through our stash of test files and I can't
> find any like that, so maybe I'm dreaming.
> Some Googling seems to indicate that the "hc-transform" node might be
> something from HighCharts... starting here
> https://github.com/highcharts/highcharts/issues/7960
> I'll let you know if I find anything more...
> SE
> On Wed, Sep 25, 2019 at 8:35 AM Even Rouault <even.rouault at spatialys.com>
> wrote:
>> On mercredi 25 septembre 2019 08:27:56 CEST Simon Eves wrote:
>> > OK, so it's a weird file.
>> > I'll leave it to you to decide whether it's worth making GDAL/Proj deal
>> > with it. I suspect not, and that's fine with us.
>> Would only be a GDAL only thing.
>> One single occurrence of such a file doesn't seem to be a very compelling
>> case.
>> Spatialys - Geospatial professional services
>> http://www.spatialys.com
> <http://www.omnisci.com/>
> Simon Eves
> Senior Graphics Engineer, Rendering Group
> OmniSci, 1 Front St. #2650, San Francisco, CA 94111, USA
> Email: simon.eves at omnisci.com | Cell: 415.902.1996
Simon Eves
100 Montgomery St (5th Floor), San Francisco, CA 94104, USA
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190926/cfda6f4f/attachment-0001.html>
