[gdal-dev] ogr2ogr VRT conversion with SQLite query not working in v. 3.0.1
Deschamps, Benjamin (EC)
benjamin.deschamps at canada.ca
Thu Sep 26 08:22:13 PDT 2019
I have a simple VRT merging data from three Shapefile sources, using an SQLITE query. The command executes without any issues with ogr2ogr v. 2.3.0 dev and with 2.1.3, but fails my new 3.0.1 install.
ogr2ogr.exe -f "ESRI Shapefile" c:\pathto\test.shp f:\pathto\cis_SGRDAMERGED_20190925_pl_a.vrt
The VRT is:
<OGRVRTDataSource>
<OGRVRTUnionLayer name="test">
<OGRVRTLayer name="cis_SGRDAHA_20190925T1800Z_pl_a">
<SrcSQL dialect="SQLITE">SELECT GEOMETRY, POLY_TYPE FROM cis_SGRDAHA_20190925T1800Z_pl_a WHERE (POLY_TYPE IS "I") AND (CT IS NOT "00") AND (CT IS NOT "01") AND (CT IS NOT "02")</SrcSQL>
<SrcDataSource>F:\pathto\cis_SGRDAHA_20190925T1800Z_pl_a.shp</SrcDataSource>
</OGRVRTLayer>
<OGRVRTLayer name="cis_SGRDAMID_20190925T1800Z_pl_a">
<SrcSQL dialect="SQLITE">SELECT GEOMETRY, POLY_TYPE FROM cis_SGRDAMID_20190925T1800Z_pl_a WHERE (POLY_TYPE IS "I") AND (CT IS NOT "00") AND (CT IS NOT "01") AND (CT IS NOT "02")</SrcSQL>
<SrcDataSource>F:\pathto\cis_SGRDAMID_20190925T1800Z_pl_a.shp</SrcDataSource>
</OGRVRTLayer>
<OGRVRTLayer name="cis_SGRDAWA_20190925T1800Z_pl_a">
<SrcSQL dialect="SQLITE">SELECT GEOMETRY, POLY_TYPE FROM cis_SGRDAWA_20190925T1800Z_pl_a WHERE (POLY_TYPE IS "I") AND (CT IS NOT "00") AND (CT IS NOT "01") AND (CT IS NOT "02")</SrcSQL>
<SrcDataSource>F:\pathto\cis_SGRDAWA_20190925T1800Z_pl_a.shp</SrcDataSource>
</OGRVRTLayer>
</OGRVRTUnionLayer>
</OGRVRTDataSource>
Error:
ERROR 1: SQL Expression Parsing Error: syntax error, unexpected string, expecting NULL or NOT. Occurred around :
POLY_TYPE IS 'I' AND CT IS NOT '02' AND CT IS NOT '01
ERROR 1: In ExecuteSQL(): sqlite3_step(SELECT GEOMETRY, POLY_TYPE FROM cis_SGRDAHA_20190925T1800Z_pl_a WHERE (POLY_TYPE IS "I") AND (CT IS NOT "00") AND (CT IS NOT "01") AND (CT IS NOT "02")):
Cannot apply attribute filter : POLY_TYPE IS 'I' AND CT IS NOT '02' AND CT IS NOT '01' AND CT IS NOT '00'
ERROR 1: SQL statement failed, or returned no layer result:
ERROR 1: In ExecuteSQL(): sqlite3_step(SELECT GEOMETRY, POLY_TYPE FROM cis_SGRDAMID_20190925T1800Z_pl_a WHERE (POLY_TYPE IS "I") AND (CT IS NOT "00") AND (CT IS NOT "01") AND (CT IS NOT "02")):
ERROR 1: In ExecuteSQL(): sqlite3_step(SELECT GEOMETRY, POLY_TYPE FROM cis_SGRDAWA_20190925T1800Z_pl_a WHERE (POLY_TYPE IS "I") AND (CT IS NOT "00") AND (CT IS NOT "01") AND (CT IS NOT "02")):
Any known issues already reported?
Thanks,
Benjamin
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190926/d90026e3/attachment.html>
