[gdal-dev] Dealing with "default" TOWGS84 values
Nyall Dawson nyall.dawson at gmail.com
Thu Apr 2 19:11:59 PDT 2020
On Fri, 3 Apr 2020 at 12:11, Nyall Dawson <nyall.dawson at gmail.com> wrote:
> On Thu, 2 Apr 2020 at 22:58, Even Rouault <even.rouault at spatialys.com> wrote:
> > Thanks for your thoughts. I've taken an intermediate approach between my initial thoughts and your suggestion, which I hope should be a reasonable default behaviour
> > Implemented per https://github.com/OSGeo/gdal/pull/2370:
> Just wanted to publicly state that I approve of the new logic and
> believe it will result in a much improved situation for users, and
> have tested the PR and can confirm it fixes the original bug reports.
Oops, and to say a big thank you to Even for his hard work here!
Nyall
