[gdal-dev] Dealing with "default" TOWGS84 values
Nyall Dawson nyall.dawson at gmail.com
Thu Apr 2 19:11:33 PDT 2020
On Thu, 2 Apr 2020 at 22:58, Even Rouault <even.rouault at spatialys.com> wrote:
> Thanks for your thoughts. I've taken an intermediate approach between my initial thoughts and your suggestion, which I hope should be a reasonable default behaviour
> Implemented per https://github.com/OSGeo/gdal/pull/2370:
Just wanted to publicly state that I approve of the new logic and
believe it will result in a much improved situation for users, and
have tested the PR and can confirm it fixes the original bug reports.
Nyall
