[gdal-dev] Dealing with "default" TOWGS84 values
Even Rouault
even.rouault at spatialys.com
Thu Apr 2 05:57:48 PDT 2020
Greg,
> Matching and skipping also feels fragile, rather than not using and
> having people that want to use them have to be explicit.
Thanks for your thoughts. I've taken an intermediate approach between my initial thoughts
and your suggestion, which I hope should be a reasonable default behaviour
Implemented per https://github.com/OSGeo/gdal/pull/2370:
Strip TOWGS84 when datum is known, in GTiff, Spatialite and GPKG drivers
Implements a simplified version of the idea mentioned in
https://lists.osgeo.org/pipermail/gdal-dev/2020-March/051881.html
with a variant of the more radical approach suggested in
https://lists.osgeo.org/pipermail/gdal-dev/2020-March/051885.html
That is the new method OGRSpatialReference::StripTOWGS84IfKnownDatumAndAllowed()
will remove TOWGS84 information from SRS whose datum name is known,
unless the OSR_STRIP_TOWGS84 configuration option is set to NO.
When TOWGS84 information is striped, a debug message is emitted.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200402/b02ddaff/attachment.html>
