[gdal-dev] gdal_translate (3.1.0dev) "never" finishes on large jpeg cogs... REALLLLLY long time to unload.
Even Rouault
even.rouault at spatialys.com
Wed Apr 15 04:38:11 PDT 2020
Andrew,
Has your source raster an alpha band ? That could explain the difference
since it isn't possible to directly create a YCbCrA JPEG compressed file, but
internally a mask band must be created. However I wouldn't anticipate such
a huge difference in performance between compression schemes. I would
suggest not setting GDAL_CACHEMAX at all and letting it at its 5% default
(increasing it is not always a good idea), in case it would be a performance
issue at de-allocating cached blocks.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200415/7f128ddb/attachment.html>
