[gdal-dev] [EXTERNAL] Re: gdal_translate (3.1.0dev) "never" finishes on large jpeg cogs... REALLLLLY long time to unload.
Ritchie, Andrew C
aritchie at usgs.gov
Wed Apr 15 12:25:46 PDT 2020
Hi Even,
Thanks for the quick response! The source dataset is a LZW cog with RGBA, and I confirmed (I think) that the issue was the mask layer by playing with the switches I used to generate the LZW cog - I didn't even have to do a JPEG COG. I can cause the same, or very similar behavior, by changing from:
-b 1 -b 2 -b 3 -b 4
to:
-b 1 -b 2 -b 3 -mask 4
with GDAL_TIFF_INTERNAL_MASK YES.
With the -b 4 switch (or omitting all -b and -mask switches), I get LZW cogs in 2 minutes. With -mask 4 I get hung up at 20% with directory thrashing messages in debug for at least 30 minutes, and I'm guessing I'll get the same behavior at the "done" message if I care to wait.
Below are the two configurations that show such a difference in performance for me. I didn't play around with CACHEMAX or MAX_DATASET_POOL_SIZE, was trying to keep it simple.
2 minute TIFFs:
gdal_translate <infile> <outfile> -b 1 -b 2 -b 3 -b 4 -of COG -co COMPRESS=LZW -co PREDICTOR=2 -co NUM_THREADS=ALL_CPUS -co RESAMPLING=AVERAGE -config GDAL_TIFF_INTERNAL_MASK YES -config GDAL_TIF_OVR_BLOCKSIZE 128
A couple orders of magnitude longer:
gdal_translate <infile> <outfile> -b 1 -b 2 -b 3 -mask 4 -of COG -co COMPRESS=LZW -co PREDICTOR=2 -co NUM_THREADS=ALL_CPUS -co RESAMPLING=AVERAGE -config GDAL_TIFF_INTERNAL_MASK YES -config GDAL_TIF_OVR_BLOCKSIZE 128
Sent: Wednesday, April 15, 2020 4:38 AM
To: gdal-dev at lists.osgeo.org
Cc: Ritchie, Andrew C <aritchie at usgs.gov>
Subject: [EXTERNAL] Re: [gdal-dev] gdal_translate (3.1.0dev) "never" finishes on large jpeg cogs... REALLLLLY long time to unload.
Andrew,
Has your source raster an alpha band ? That could explain the difference since it isn't possible to directly create a YCbCrA JPEG compressed file, but internally a mask band must be created. However I wouldn't anticipate such a huge difference in performance between compression schemes. I would suggest not setting GDAL_CACHEMAX at all and letting it at its 5% default (increasing it is not always a good idea), in case it would be a performance issue at de-allocating cached blocks.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200415/769efa58/attachment.html>
