[gdal-dev] NetCDF rotated grid support
Rousseau Lambert2, Louis-Philippe (EC) louis-philippe.rousseaulambert2 at canada.ca
Wed Apr 15 06:58:27 PDT 2020
Thanks Even for your answer.
Than I guess it's a problem with my NetCDF projection definition since it is not projected correctly when I view it...
I also found out that I cannot reproject those NetCDF (with a rotated grid) to a standard projection like EPSG:4326, it fails with:
ERROR 1: Too many points (441 out of 441) failed to transform, unable to compute output bounds.
I will try to solve this with the data producer
Thanks
LP
On 2020-04-14 13:26, Even Rouault wrote:
Louis-Phillipe,
Reading netCDF or GRIB2 rotated grids works, but not writing them to netCDF. That could potentially be added, but this is not handled currently.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200415/5f00fc02/attachment.html>
