[gdal-dev] NetCDF rotated grid support
Even Rouault
even.rouault at spatialys.com
Wed Apr 15 07:13:05 PDT 2020
Louis-Philippe,
Support for rotated grid is a nightmare due to different conventions used for GRIB, netCDF
or PROJ ob_tran method. The GDAL GRIB and netCDF drivers normally do what is needed
map from the native product convention to the PROJ one.
Below 2 emails I wrote some time ago the OGC CRS SWG group which might bring some light
(or deep obscurity!) to this topic:
1)
Rotated pole/grid
To: "crs.swg at lists.opengeospatial.org" <crs.swg at lists.opengeospatial.org>
Date: 03/10/2019 14:26
Hi again,
(was initially a part of my previous email about "Expressing a ProjectedCRS of
a DerivedGeographicCRS", but this deserves its own thread)
Standardization of rotated pole is another interesting/annoying topic I've
discussed with a few people privately. This tends to be tricky as I always
stumble on different conventions regarding the semantics of parameters and the
maths behind.
For posterity, and my own recollection, here are my latest findings:
1) PROJ's ob_tran (https://proj.org/operations/projections/ob_tran.html)
formulas are a straightforward implementation from Snyder's "Map projections -
a working manual", in particular equations (5-7) and (5-8b) for the forward
path, at page 31 of https://pubs.usgs.gov/pp/1395/report.pdf
(although I've some disagreement with the 'new pole' terminology currently
used in the above HTML help page:
https://github.com/OSGeo/PROJ/pull/1653 )
2) But they are different from the conventions used for PDS3 or ISIS3
planetary image formats, a bit like if the forward and inverse paths had been
switched, so you need to 'switch' parameters, do crazy things like 180 -
pole_latitude, etc when crossing different conventions... Interestingly one
doc for PDS3 mentions at the middle of page 10 of https://pds-imaging.jpl.nasa.gov/
documentation/Cassini_BIDRSIS.PDF that "The derivation
of these equations is given in reference [12], p. 29—32, but a
critical pair of signs appear to be exchanged between the formulae
for the forward and inverse transformations. Reference [13], p. 6,
gives the correct forward transformation, and reference [14], pp. 77—
78, give both the forward and inverse transformations"
"reference [12] p29-32" is Snyder's "Map projections - a working manual" I
mentionned before. So this somewhat acknowledges the existence of different
conventions (not sure if there are really "wrong" and "correct" ones)
reference [13] is "Bugayevskiy, L. M., and Snyder, J. P., 1995, Map
projections: A reference manual, Taylor & Francis, London and Bristol,
Pennsylvania, 328 pp."
and [14] "Yang, Q. H., Snyder, J. P., and Tobler, W. R., 2000, Map projection
transformations: Principles and applications, Taylor & Francis, London and
Bristol, Pennsylvania, 367 pp"
PDS/ISIS3 implementation of [13] and [14] is in
https://github.com/USGS-Astrogeology/ISIS3/blob/3.8.0/isis/src/base/objs/
ObliqueCylindrical/ObliqueCylindrical.cpp#L311
3) When dealing with netCDF rotated pole, I've also seen issues with
conventions.
An implementation of that convention is in netcdf-java:
https://github.com/Unidata/netcdf-java/blob/
3ce72c0cd167609ed8c69152bb4a004d1daa9273/cdm/core/src/main/java/ucar/unidata/
geoloc/projection/RotatedPole.java
4) GRIB2 also uses a yet another different convention (with south pole
coordinates as parameters)
An implementation of that convention is also in netcdf-java in
geoloc/projection/RotatedLatLon.java
I was also pointed by a data producer of GRIB2 rotated pole datasets that they
used https://www.mathworks.com/matlabcentral/fileexchange/43435-rotated-grid-transform?focused=3795951&tab=function&ue&nocookie=true as the inspiration for
their maths, and luckily it gives consistent result with the Java
RotatedLatLon code.
All in all, a lot of confusion which I think depends if you consider north
pole vs south pole, or the coordinates of the unrotated pole in the rotated
grid, or the coordinates of the new rotated pole in the unrotated grid...
As far as I experimented, there's always a way of using a given implementation
(in my case ob_tran) with the other conventions by tweaking the values of the
3 angular parameters. So, despite the diversity of conventions, considering
standardizing one could still be useful.
Even
2)
Re: Rotated pole/grid
Date: 22/11/2019 02:35
reviving this not-so-exciting topic :-)...
For the purpose of dealing with GRIB rotated long/lat grids,
https://www.nco.ncep.noaa.gov/pmb/docs/grib2/grib2_doc/grib2_temp3-1.shtml,
I'm about to use a "Pole rotation (GRIB convention)" conversion method with
the following 3 parameters, whose naming and semantics comes mostly from the above GRIB
spec:
- "Latitude of the southern pole (GRIB convention)"
Latitude of the point from the unrotated
CRS, expressed in the unrotated CRS, that will become the south pole of the
rotated CRS.
- "Longitude of the southern pole (GRIB convention)"
Longitude of the point from the unrotated
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200415/1e55b456/attachment-0001.html>
