[gdal-dev] Interpolation used for egm96_15.gtx when using RPC_DEM_APPLY_VDATUM_SHIFT
Yann-Sebastien Tremblay-Johnston yanns.tremblay at gmail.com
Fri Apr 17 10:27:37 PDT 2020
Hi Even,
To start with, you need the the dataset pointed by RPC_DEM is a compoundCRS
> with a vertical CRS properly defined
Thanks, I initially didn't understand why this wasn't working as the SRTM
DEM I am using does not have a compoundCRS. I worked around this by
creating a VRT with the correct compoundCRS.
 Interpolation of the geoid grid is done by PROJ itself, and this is
> bilinear interpolation
Awesome, good to know. Is there anyway of configuring this?
Thanks for the quick response.
Sebastien
On Fri, Apr 17, 2020 at 10:09 AM Even Rouault <even.rouault at spatialys.com>
wrote:
> Yann-Sebastien,
> > I spent a bit of time learning about vertical datum shifts when
> performing
> > RPC coordinate transformations using a DEM this week, and I was curious
> > about how the egm96_15.gtx file is interpolated. I was able to find in
> > gdal_rpc.cpp that the required vdatum shift is calculated using an OGR
> > Coordinate Transformation between the DEM spatial reference and a wgs84
> > ellipsoid spatial reference, but I’m not familiar enough with OGR/PROJ to
> > understand exactly how the gtx file is sampled.
> compoundCRS with a vertical CRS properly defined and an existing
> transformation between that vertical CRS and WGS84, so if it is something
> like EPSG:XXXX+5773, that will be fine.
> bilinear interpolation.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200417/f4b05034/attachment.html>
