[gdal-dev] Interpolation used for egm96_15.gtx when using RPC_DEM_APPLY_VDATUM_SHIFT
Even Rouault
even.rouault at spatialys.com
Fri Apr 17 10:34:03 PDT 2020
> Interpolation of the geoid grid is done by PROJ itself, and this is
> > bilinear interpolation
> Awesome, good to know. Is there anyway of configuring this?
Depends on your definition of configuring. As it is open source, everything is
somehow configurable. Here changing the lines of code starting at
https://github.com/OSGeo/PROJ/blob/master/src/grids.cpp#L3226 :-)
But people seem to be generally happy with bilinear interpolation.
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200417/f728eff9/attachment.html>
