[gdal-dev] Does OGR support GeoPackage enums in write mode (or at all?)
Andrea Aime
andrea.aime at geo-solutions.it
Fri Apr 17 10:55:06 PDT 2020
HI Even,
talked with Jeff Yutzler, he confirmed enums are meant to be used as I
described before, but their support
has been not picked up in libraries. Believe I'm going to implement it in
GeoTools soon.
Cheers
Andrea
On Wed, Apr 15, 2020 at 11:56 AM Andrea Aime <andrea.aime at geo-solutions.it>
wrote:
> On Wed, Apr 15, 2020 at 11:36 AM Even Rouault <even.rouault at spatialys.com>
> wrote:
>> > http://www.geopackage.org/spec/
>> My understanding of table 27 is that it is just to define constraints on
>> the values of a column, but not a way to establish a integer<-->string
>> mapping as you'd like. Unless I'm missing something. Of course you could
>> create an auxiliary table with the mapping, but I'm not aware of a
>> standardized way of registering it.
> I had the idea because Table 27 lists enum values (in the "value" column)
> as 1, 2, 3, and while not providing an example of it,
> gpkg_data_column_constraints
> also has a "description" column. so my current guess is that one could use
> integer numbers in "value", and provide the name of the value in
> "description".
> I'm going to follow up with the OGC spec lead to see if that was an actual
> option, or just a thing in my mind... and will let you know what comes out
> of it :-D
> Cheers
> Andrea
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf
> Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa
> (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549
> http://www.geo-solutions.it http://twitter.com/geosolutions_it
> ------------------------------------------------------- *Con riferimento
> alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 -
> Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni
> circostanza inerente alla presente email (il suo contenuto, gli eventuali
> allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i
> destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per
> errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le
> sarei comunque grato se potesse darmene notizia. This email is intended
> only for the person or entity to which it is addressed and may contain
> information that is privileged, confidential or otherwise protected from
> disclosure. We remind that - as provided by European Regulation 2016/679
> “GDPR” - copying, dissemination or use of this e-mail or the information
> herein by anyone other than the intended recipient is prohibited. If you
> have received this email by mistake, please notify us immediately by
> telephone or e-mail.*
Regards, Andrea Aime
== GeoServer Professional Services from the experts! Visit
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200417/bea08985/attachment-0001.html>
