[gdal-dev] vsis3 to access a .vrt
Brian mulcahy.brianp at gmail.com
Fri Apr 17 15:35:46 PDT 2020
Its strange because it works just fine when sitting on the filesystem, but
in a private bucket the error, cant find file or missing directory or
corrupt file,  shows. I don't have the error in front of me at the moment
so that may not be the exact words. I'll keep trying if I still can't get
it to work ill see if I can rig up some data I can share.
On Fri, Apr 17, 2020, 5:07 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> On vendredi 17 avril 2020 15:49:58 CEST Brian wrote:
> > Is using vsis3 to access a vrt possible? I have exhausted my debugging
> > skills. I can read .tifs just fine but as soon as I try a vrt it gives me
> > corrupt empty or missing file. The call for using vsis3 is coming from
> > mapserver but I thought this would be a gdal issue. Could anyone verify
> for
> > me that accessing a .vrt is possible with vsis3? If not how should I be
> > accessing it?
> Works for me (TM). There's no reason that accessing .vrt through /vsis3/
> wouldn't work as well/as worse than a .tif
> You'd have to be more specific of what you do exactly, errors you get, etc
> etc
> Perhaps check the content of the VRT itself. If source filenames are
> correct, if the relativeToVRT attribute is properly set, etc
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200417/1ba1a60d/attachment.html>
