[gdal-dev] Replacement for +init when using +lon_wrap
Even Rouault
even.rouault at spatialys.com
Wed Apr 22 10:28:38 PDT 2020
Mika,
You're using an advanced PROJ feature, with no equivalent in ISO
CRS modeling, so there's no direct replacement. You can still go on
with the old syntax. Or expand to "+proj=longlat +datum=WGS84
+lon_wrap=180" if you want to avoid the warning
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200422/b7da32d3/attachment.html>
