[gdal-dev] libgeotiff 1.6.0 RC1 available
Even Rouault
even.rouault at spatialys.com
Wed Apr 22 11:24:40 PDT 2020
I've prepared a libgeotiff 1.6.0 release candidate
Sources at:
- http://download.osgeo.org/geotiff/libgeotiff/libgeotiff-1.6.0rc1.tar.gz
- http://download.osgeo.org/geotiff/libgeotiff/libgeotiff-1.6.0rc1.zip
It is used as the internal libgeotiff copy in GDAL master.
I'll call for a vote for promoting it to final soon if I don't hear about serious issues with it.
Changelog:
New features:
* Add support for OGC GeoTIFF 1.1
* Expose GTIFGetPCSInfoEx(), GTIFGetProjTRFInfoEx(), GTIFGetGCSInfoEx(),
GTIFGetDatumInfoEx(), GTIFGetEllipsoidInfoEx(), GTIFGetPMInfoEx(),
GTIFGetUOMLengthInfoEx() and GTIFGetUOMAngleInfoEx() so that users can specify their
own PROJ context
* Add GTIFKeyGetASCII(), GTIFKeyGetSHORT() and GTIFKeyGetDOUBLE() as safer variants of
GTIFKeyGet() with type checking
* autotools build: enable build in a separate tree from source (#37) (fixes #28)
* Use pkg-config for libtiff detection
Bug fixes:
* GTIFDecToDMS(): fix rounding issue (refs #16)
* geo_names.c: Silence warning in GetNameFromDatabase
* cpl_serv.h: add parenthesis in macro definitions
* Fix spelling errors
* geo_normalize.c: set UOMLength from GeogLinearUnits (for geocentic CRS) (GDAL #1595)
* testlistgeo: remove hardcoded path in test output (fixes https://github.com/OSGeo/
libgeotiff/issues/16#issuecomment-502267406)
* Adapt test script for PROJ 6.2 EPSG database (fixes #22)
* Use unix EOL for cmake related files (fixes #14)
* configure.ac: drop dead code
* geo_normalize.c: avoid look up of user-defined geokeys that cause PROJ warnings (fixes
GDAL #2321)
* listgeo: fix corner coordinates for images with RasterPixelIsPoint (#36)
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200422/d192111e/attachment.html>
