[gdal-dev] Storing mask as part of the *.ovr file
Denis Rykov rykovd at gmail.com
Thu Apr 23 01:27:13 PDT 2020
Thanks! Could you please explain the meaning of INTERNAL_MASK_FLAGS_1=2? I
couldn't find it in the documentation.
On Thu, Apr 23, 2020, 12:44 AM Even Rouault <even.rouault at spatialys.com>
wrote:
> > But if I do:
> > gdal_translate rgbmask.vrt rgb_with_external_msk.vrt -mask none -b 1 -b
> > 2 -b 3 -of VRT
> I guess in the above you meant without "-mask none", so
> "gdal_translate rgbmask.vrt rgb_with_external_msk.vrt -b 1 -b 2 -b 3 -of
> VRT"
> Well, that's a consequence of the behaviour of the 'auto' mode of -mask in
> https://gdal.org/programs/gdal_translate.html#cmdoption-gdal-translate-mask
> This is admitedly not super intuitive as the example I gave before lacked
> the "-mask none" when generating rgb_with_external_msk.vrt
> As you copy all non-mask input band, and mask is in auto mode, and thus
> copied too, this is equivalent to
> gdal_translate rgbmask.vrt rgb_with_external_msk.vrt -of VRT
> and the VRT driver is then smart enough to detect that its source is a
> VRT, so it is an equivalent of a single "cp" of the original VRT.
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200423/0b2be8e3/attachment.html>
