[gdal-dev] Is there a way to build GDAL without FreeType?
Jeff McKenna
jmckenna at gatewaygeomatics.com
Mon Apr 27 05:25:23 PDT 2020
Hi Craig,
Maybe your GDAL build uses libPoppler, which references the Freetype
lib; you could disable that from your GDAL build and retry.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
https://gatewaygeo.com/
On 2020-04-25 4:40 p.m., Craig Delancy wrote:
> (Windows 10, 64-bit)
> Is there a way to compile GDAL (3.0.4) without the dependency on FreeType?
> I am trying to integrate the GDAL libraries into an existing software,
> which itself already links to FreeType2. This causes a series of
> conflicts such as:
> freetype.lib(ftbase.obj) : error LNK2005: FT_DivFix already defined in
> gdal_i.lib(gdal300.dll)
> These prevent me from being able to link GDAL and compile the
> executable. Is there a way to remove the dependency, or another way to
> resolve the multiple definitions?
> Thanks.
