[gdal-dev] Building for Java on MacOS
Even Rouault even.rouault at spatialys.com
Mon Apr 27 06:11:33 PDT 2020
On lundi 27 avril 2020 07:03:28 CEST David Rush wrote:
> All:
> I think I finally found some instructions for building the Java stuff I
> need:
> https://trac.osgeo.org/gdal/wiki/GdalOgrInJavaBuildInstructionsUnix
> That includes some notes for MacOS.  Yay.
> I've set up my java.opt per this link referenced in the above link:
> https://trac.osgeo.org/gdal/ticket/2401
> But when I run "make" from the swig/java directory, I get this error:
> GNUmakefile:1: ../../GDALmake.opt: No such file or directory
> make: *** No rule to make target `../../GDALmake.opt'.  Stop.
> I did a search with "find" but I don't seem to have that file.
You need to run ./configure to generate it. And it is strongly advise that you run the Java
bindings against the same version of the native library for which they have been generated.
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200427/7353f432/attachment.html>
