[gdal-dev] Building for Java on MacOS
David Rush
david.rush at wyo.gov
Mon Apr 27 07:02:10 PDT 2020
Thank you, Evan. That got me to the next error:
/bin/sh: swig: command not found
make: *** [gdal_wrap.cpp] Error 127
Where/how does the "swig" script or binary come from?
David
On Mon, Apr 27, 2020 at 7:11 AM Even Rouault <even.rouault at spatialys.com>
wrote:
> On lundi 27 avril 2020 07:03:28 CEST David Rush wrote:
> > All:
> > I think I finally found some instructions for building the Java stuff I
> > need:
> > https://trac.osgeo.org/gdal/wiki/GdalOgrInJavaBuildInstructionsUnix
> > That includes some notes for MacOS. Yay.
> > I've set up my java.opt per this link referenced in the above link:
> > https://trac.osgeo.org/gdal/ticket/2401
> > But when I run "make" from the swig/java directory, I get this error:
> > GNUmakefile:1: ../../GDALmake.opt: No such file or directory
> > make: *** No rule to make target `../../GDALmake.opt'. Stop.
> > I did a search with "find" but I don't seem to have that file.
> You need to run ./configure to generate it. And it is strongly advise that
> you run the Java bindings against the same version of the native library
> for which they have been generated.
> Spatialys - Geospatial professional services
> http://www.spatialys.com
E-Mail to and from me, in connection with the transaction
of public
business, is subject to the Wyoming Public Records
Act and may be
disclosed to third parties.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200427/aa283cb0/attachment-0001.html>
