[gdal-dev] Building for Java on MacOS
David Rush
david.rush at wyo.gov
Mon Apr 27 07:27:00 PDT 2020
Ivan:
Thanks! That worked. On to the next error (with make in gdal/swig/java)
gdalconst_wrap.c:154:10: fatal error: 'jni.h' file not found
#include <jni.h>
1 error generated.
make: *** [gdalconst_wrap.lo] Error 1
Where *should* jni.h come from? I can't find it anywhere in my Java
installation.
David
On Mon, Apr 27, 2020 at 8:18 AM Ivan Lucena <ivan.lucena at outlook.com> wrote:
> Hi David,
> I am in the process of refreshing my GDAL building process in a Mac, so I
> might be able to help with that question.
> You need to install SWIG in your machine. And one way to do that is using
> the HomeBrewer [brew.sh] another is Anaconda [anaconda.com]
> $ brew install swig
> or
> $ conda install swig
> Homebrew mess with you OS and Apple updates might mess with your brew
> installed software. Anaconda keeps it all in a user sub-folder. It is up
> to you.
> I am not interested in building the Java binding, only Python, but once
> upon a time I remember I could get all you need "just" by installing uDig [
> udig.refractions.net]. I mean, the GDAL Java binding was included and
> ready to use.
> Regards,
> Ivan
> *From:* gdal-dev <gdal-dev-bounces at lists.osgeo.org> on behalf of David
> Rush <david.rush at wyo.gov>
> *Sent:* Monday, April 27, 2020 10:02 AM
> *To:* gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
> *Subject:* Re: [gdal-dev] Building for Java on MacOS
> Thank you, Evan. That got me to the next error:
> /bin/sh: swig: command not found
> make: *** [gdal_wrap.cpp] Error 127
> Where/how does the "swig" script or binary come from?
> David
> On Mon, Apr 27, 2020 at 7:11 AM Even Rouault <even.rouault at spatialys.com>
> wrote:
> On lundi 27 avril 2020 07:03:28 CEST David Rush wrote:
> > All:
> > I think I finally found some instructions for building the Java stuff I
> > need:
> > https://trac.osgeo.org/gdal/wiki/GdalOgrInJavaBuildInstructionsUnix
> > That includes some notes for MacOS. Yay.
> > I've set up my java.opt per this link referenced in the above link:
> > https://trac.osgeo.org/gdal/ticket/2401
> > But when I run "make" from the swig/java directory, I get this error:
> > GNUmakefile:1: ../../GDALmake.opt: No such file or directory
> > make: *** No rule to make target `../../GDALmake.opt'. Stop.
> > I did a search with "find" but I don't seem to have that file.
> You need to run ./configure to generate it. And it is strongly advise that
> you run the Java bindings against the same version of the native library
> for which they have been generated.
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> E-Mail to and from me, in connection with the transaction
> of public business, is subject to the Wyoming Public Records
> Act and may be disclosed to third parties.
of public
Act and may be
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200427/385a5150/attachment-0001.html>
