[gdal-dev] GDAL 3.1.0 RC1 available
Even Rouault even.rouault at spatialys.com
Tue Apr 28 08:15:58 PDT 2020
Issue fixed now. I'll re-issue a RC2 soon to address this.
Unrelated notes regarding
https://github.com/DanielFEvans/gdalmanylinux/blob/gdal_3.1.0/Dockerfile.wheels
- Jasper probably unneeded as you use openjpeg which is normally superior to it
- PROJ could be bumped to 6.3.1 or 7.0.0. And within a few days to 6.3.2 / 7.0.1 once they are
promoted to final
- if you're somehow interested in accurate geodetic datum transformations, you'd better
install some grids. See https://proj.org/download.html for options. With PROJ >= 7.0, you can
also set the env variable PROJ_NETWORK=ON for on-demand fetching of needed grids
through the network.
- openjpeg could/should be bumped to 2.3.1
- hdf5, netcdf could potentially be bumped too to 1.12.0 and 4.7.4. See https://github.com/
OSGeo/gdal/blob/master/gdal/docker/alpine-normal/Dockerfile
- webp presumably too
- --with-static-proj4=/usr/local is deprecated ==> --with-proj=/usr/local
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200428/cbca9ec8/attachment.html>
