[gdal-dev] GDAL 3.1.0 RC1 available
Norman Barker
norman.barker at gmail.com
Tue Apr 28 15:23:50 PDT 2020
Hi Even,
Does https://github.com/OSGeo/gdal/pull/2397 need to be included in the
notes for this RC? I see the code is in the release which is great, thank
you.
I have checked over the other TileDB functions in this RC and it looks good
to me.
Norman
On Tue, Apr 28, 2020 at 10:16 AM Even Rouault <even.rouault at spatialys.com>
wrote:
> Issue fixed now. I'll re-issue a RC2 soon to address this.
> Unrelated notes regarding
> https://github.com/DanielFEvans/gdalmanylinux/blob/gdal_3.1.0/Dockerfile.wheels
> - Jasper probably unneeded as you use openjpeg which is normally superior
> to it
> - PROJ could be bumped to 6.3.1 or 7.0.0. And within a few days to 6.3.2 /
> 7.0.1 once they are promoted to final
> - if you're somehow interested in accurate geodetic datum transformations,
> you'd better install some grids. See https://proj.org/download.html for
> options. With PROJ >= 7.0, you can also set the env variable
> PROJ_NETWORK=ON for on-demand fetching of needed grids through the network.
> - openjpeg could/should be bumped to 2.3.1
> - hdf5, netcdf could potentially be bumped too to 1.12.0 and 4.7.4. See
> https://github.com/OSGeo/gdal/blob/master/gdal/docker/alpine-normal/Dockerfile
> - webp presumably too
> - --with-static-proj4=/usr/local is deprecated ==> --with-proj=/usr/local
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200428/9abd7bfb/attachment.html>
