[gdal-dev] PDF generation on Linux
Andrew C Aitchison
andrew at aitchison.me.uk
Wed Aug 12 06:53:41 PDT 2020
On Wed, 12 Aug 2020, Kélian Devillier wrote:
> Hello,
> I'm trying to work with GeospatialPDF generation from an XML file on Linux.
> Using Ubuntu 18.04, I compiled the sources from version 3.0.4 myself.
> Unfortunately, when I tried to execute the Python script with my xml, I got
> the following message :
> ERROR 6: PDF node not supported due to PDF read support in this GDAL build
> Is it due to the fact that I don't have any PDF viewer capable of reading
> GeospatialPDF installed ?
No.
> And if that is the case, is there any way of bypassing the error, given
> that I can just transfer the file to a Windows system to read it.
What do
gdalinfo --formats |& grep -i pdf
and
ogrinfo --formats |& grep -i pdf
report ?
Does the system gdalinfo or ogrinfo (v2.?? IIRC) give a different answer ?
Did you include any of the configure options
--with-poppler=...
--with-podofo=...
--with-pdfium=...
--disable-driver-pdf
--enable-pdf-plugin
when you built gdal ?
The --with-... options may require a suitable path to the library.
I'm not sure whether all of these have PDF write support.
Andrew C. Aitchison Kendal, UK
