[gdal-dev] gdal 3.1.2 installation in RHEL 7 , stuck with dependency installation. kindly help
Kavitha K
kmskavi at gmail.com
Thu Aug 13 05:08:05 PDT 2020
Hi All,
export PKG_CONFIG_PATH=/usr/local/lib/pkgconfig
Step 1: gdal 3.1.2
[root at test-22 gdal-3.1.2]# ./configure
configure: Bash completions not requested
checking for PROJ >= 6 library... checking for proj_create_from_wkt in
-lproj... no
checking for internal_proj_create_from_wkt in -lproj... no
checking for internal_proj_create_from_wkt in -linternalproj... no
configure: error: PROJ 6 symbols not found
Step 2: PROJ 6
[root at test-22 proj-6.3.2]#
checking for pkg-config... /usr/local/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
checking for SQLITE3... configure: error: Package requirements (sqlite3 >=
3.11) were not met:
No package 'sqlite3' found
Consider adjusting the PKG_CONFIG_PATH environment variable if you
installed software in a non-standard prefix.
Alternatively, you may set the environment variables SQLITE3_CFLAGS
and SQLITE3_LIBS to avoid the need to call pkg-config.
See the pkg-config man page for more details.
Step 3:
[root at pi-22 gdalDevKits]# pwd
/root/gdalDevKits
[root at pi-22 gdalDevKits]# ls |grep sql
sqlite-tools-linux-x86-3320300
sqlite-tools-linux-x86-3320300.zip
[root at pi-22 gdalDevKits]# cd sqlite-tools-linux-x86-3320300
[root at pi-22 sqlite-tools-linux-x86-3320300]# ls
sqldiff sqlite3 sqlite3_analyzer
[root at pi-22 sqlite-tools-linux-x86-3320300]# cd /usr/local/bin
[root at pi-22 bin]# ls |grep sql
sqldiff
sqlite3
sqlite3_analyzer
[root at pi-22 bin]# pwd
/usr/local/bin
[root at pi-22 bin]# cd /usr/local/lib
[root at pi-22 lib]# ls | grep pk
pkgconfig
Step 4:
Still we are hitting " No package 'sqlite3' found" while installing the
proj6
Kindly help.
Thanks,
Kavitha
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200813/efdb422e/attachment.html>
