[gdal-dev] gdal 3.1.2 installation in RHEL 7 , stuck with dependency installation. kindly help
Mateusz Loskot mateusz at loskot.net
Thu Aug 13 05:49:40 PDT 2020
On Thu, 13 Aug 2020 at 14:08, Kavitha K <kmskavi at gmail.com> wrote:
> checking for SQLITE3... configure: error: Package requirements (sqlite3 >= 3.11) were not met:
> No package 'sqlite3' found
> Consider adjusting the PKG_CONFIG_PATH environment variable if you
> installed software in a non-standard prefix.
> Alternatively, you may set the environment variables SQLITE3_CFLAGS
> and SQLITE3_LIBS to avoid the need to call pkg-config.
> See the pkg-config man page for more details.
> [root at pi-22 sqlite-tools-linux-x86-3320300]# cd /usr/local/bin
> [root at pi-22 bin]# ls |grep sql
> sqldiff
> sqlite3
> sqlite3_analyzer
You need SQLite development package, with header(s) and library,
not just SQLite executable program(s).
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
