[gdal-dev] OSRGetPROJSearchPaths unexpected behaviour
Javier Jimenez Shaw
j1 at jimenezshaw.com
Mon Aug 17 09:07:07 PDT 2020
Hi
I have been using OSRSetPROJSearchPaths so far.
Now, to test if "anybody" changed those paths (like another library), I am
calling OSRGetPROJSearchPaths. However, even if I call one after the other,
I get something different from OSRGetPROJSearchPaths.
I guess OSRGetPROJSearchPaths is getting the data from proj_info, that
calls pj_get_default_ctx. So it is not updated with the data I set in
OSRSetPROJSearchPaths. Is that the case? If yes, is it intentional? I was
expecting exactly the values I had set one line above with
Thanks,
Javier
.___ ._ ..._ .. . ._. .___ .. __ . _. . __.. ... .... ._ .__
Entre dos pensamientos racionales
hay infinitos pensamientos irracionales.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200817/3e7635b9/attachment.html>
