[gdal-dev] Required PROJ data in PROJ7
Michael Smith
michael.smith.erdc at gmail.com
Wed Aug 19 14:57:29 PDT 2020
John
New proj now adds support for geotiffs for datums, much smaller and can be accessed over net, subset, etc. There is a CDN for the data, cdn.prog.org as well as a utility for fetching data, https://proj.org/apps/projsync.html.
You can use the online CDN to just fetch what a user needs at runtime and never download, or you can download ahead of time, whatever subsets you need.
Mike
Michael Smith
US Army Corps of Engineers
Remote Sensing/GIS Center
On 8/19/20, 5:05 PM, "gdal-dev on behalf of John Daniel" <gdal-dev-bounces at lists.osgeo.org on behalf of jdaniel at etresoft.com> wrote:
Hello,
The old proj-datumgrid is divided into a small, 13 MB required dataset and a number of much larger optional regional datasets. The new proj-data doesn't seem to have this distinction. It is smaller overall, but still 500 MB.
I am interested in using GDAL in mobile apps so I don't want to include that much data. Is there a smaller set of proj-data files that can be used instead? Which of those files are required and which can be omitted? For example, it is possible to split the data by region, but with the software work with only a partial set of files? Can the data files be downloaded at runtime, on demand? If so, I'm sure I will need to include a few of them by default.
It looks like PROJ 7 can still be used with the old data. Is PROJ 7 safe for use with other projects? I have seen some messages that suggested that this was a problem for some projects. I think Spatialite was one. I won't be distributing with GPL projects like GEOS or Spatialite, but I would still like to use them for local testing.
Thanks.
John Daniel
Etresoft, Inc.
gdal-dev mailing list
gdal-dev at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/gdal-dev
