[gdal-dev] gdalbuildvrt could not use worldfile
Idan Miara
idan at miara.com
Thu Aug 20 04:49:31 PDT 2020
According to gdalinfo your vrt looks fine, so it might be a problem with
the vrt support in mapviewer.
What are you trying to accomplish with this vrt? if you just want to
georeference your tif you could try:
gdal_translate -of GTiff input.tif ouput.tif
use "-co COMPRESS=DEFLATE -co TILED=YES -co BIGTIFF=IF_SAFER" or other
gtiff parameters as needed:
https://gdal.org/drivers/raster/gtiff.html
Idan
On Thu, 20 Aug 2020 at 12:49, APM <apschwimmer at apmland.de> wrote:
> Hello list,
> I'm a beginner with gdal and use Linux Debian testing as the OS.
> I like to create a .vrt file to use a map.
> The map comes with a worldfile .tfw:
> 1.2700000000
> 0.0000000000
> 0.0000000000
> -1.2700000000
> 376279.1000000000
> 5679613.9199999999
> If I try to build the .vrt by using
> gdalbuildvrt map_1.vrt map_1.tif
> The .vrt is present now.
> But I can't use it in a mapviewer, which gives out a message, that the
> georeferences are not present.
> gdalinfo map_1.tif
> Driver: GTiff/GeoTIFF
> Files: map_1.tif
> map_1.tfw
> Size is 16252, 13444
> Origin = (376278.464999999967404,5679614.554999999701977)
> Pixel Size = (1.270000000000000,-1.270000000000000)
> Image Structure Metadata:
> COMPRESSION=DEFLATE
> INTERLEAVE=PIXEL
> Corner Coordinates:
> Upper Left ( 376278.465, 5679614.555)
> Lower Left ( 376278.465, 5662540.675)
> Upper Right ( 396918.505, 5679614.555)
> Lower Right ( 396918.505, 5662540.675)
> Center ( 386598.485, 5671077.615)
> Band 1 Block=128x128 Type=Byte, ColorInterp=Red
> NoData Value=0
> Band 2 Block=128x128 Type=Byte, ColorInterp=Green
> NoData Value=0
> Band 3 Block=128x128 Type=Byte, ColorInterp=Blue
> NoData Value=0
> gdalinfo map_1.vrt
> Driver: VRT/Virtual Raster
> Files: map_1.vrt
> map_1.tif
> Corner Coordinates:
> NoData Value=0
> NoData Value=0
> NoData Value=0
> Can you give me a hint, please?
> Thank you!
> KR
> Piet
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200820/dd5e22b7/attachment.html>
