[gdal-dev] gdalbuildvrt could not use worldfile
Idan Miara
idan at miara.com
Thu Aug 20 05:19:33 PDT 2020
It might indeed be the missing CRS info (world files include only the pixel
size and corner pixel).
Try to add the -a_srs parameter as Jukka suggested.
for instance, add "-a_srs EPSG:32632" (if you are using WGS84 / UTM Zone
32N https://epsg.io/32632 <https://epsg.io/32630>)
On Thu, 20 Aug 2020 at 15:11, APM <apschwimmer at apmland.de> wrote:
> Dear Idan,
> thank you for your input.
> I use the .vrt step to assemble a group of tif's to one common file.
> In a second step I use something like
> gdal_translate -of GTiff -co COMPRESS=LZW -co tiled=yes maps.vrt maps.tiff
> But the maps.tiff has no georeference data's as well.
> This two steps works well with other Geotiff tiles, but maybe there's a
> more easy way to create one map from several tiles.
> Kind regards
> Piet
> Am 20.08.20 um 13:49 schrieb Idan Miara:
> Hi,
> According to gdalinfo your vrt looks fine, so it might be a problem with
> the vrt support in mapviewer.
> What are you trying to accomplish with this vrt? if you just want to
> georeference your tif you could try:
> gdal_translate -of GTiff input.tif ouput.tif
> use "-co COMPRESS=DEFLATE -co TILED=YES -co BIGTIFF=IF_SAFER" or other
> gtiff parameters as needed:
> https://gdal.org/drivers/raster/gtiff.html
> Idan
> On Thu, 20 Aug 2020 at 12:49, APM <apschwimmer at apmland.de> wrote:
>> Hello list,
>> I'm a beginner with gdal and use Linux Debian testing as the OS.
>> I like to create a .vrt file to use a map.
>> The map comes with a worldfile .tfw:
>> 1.2700000000
>> 0.0000000000
>> 0.0000000000
>> -1.2700000000
>> 376279.1000000000
>> 5679613.9199999999
>> If I try to build the .vrt by using
>> gdalbuildvrt map_1.vrt map_1.tif
>> The .vrt is present now.
>> But I can't use it in a mapviewer, which gives out a message, that the
>> georeferences are not present.
>> gdalinfo map_1.tif
>> Driver: GTiff/GeoTIFF
>> Files: map_1.tif
>> map_1.tfw
>> Size is 16252, 13444
>> Origin = (376278.464999999967404,5679614.554999999701977)
>> Pixel Size = (1.270000000000000,-1.270000000000000)
>> Image Structure Metadata:
>> COMPRESSION=DEFLATE
>> INTERLEAVE=PIXEL
>> Corner Coordinates:
>> Upper Left ( 376278.465, 5679614.555)
>> Lower Left ( 376278.465, 5662540.675)
>> Upper Right ( 396918.505, 5679614.555)
>> Lower Right ( 396918.505, 5662540.675)
>> Center ( 386598.485, 5671077.615)
>> Band 1 Block=128x128 Type=Byte, ColorInterp=Red
>> NoData Value=0
>> Band 2 Block=128x128 Type=Byte, ColorInterp=Green
>> NoData Value=0
>> Band 3 Block=128x128 Type=Byte, ColorInterp=Blue
>> NoData Value=0
>> gdalinfo map_1.vrt
>> Driver: VRT/Virtual Raster
>> Files: map_1.vrt
>> map_1.tif
>> Corner Coordinates:
>> NoData Value=0
>> NoData Value=0
>> NoData Value=0
>> Can you give me a hint, please?
>> Thank you!
>> KR
>> Piet
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200820/3127aca1/attachment-0001.html>
