[gdal-dev] I have a problem getting higher resolution in a VRT file
jratike80
jukka.rahkonen at maanmittauslaitos.fi
Thu Aug 20 05:23:42 PDT 2020
Even Rouault-2 wrote
> By default, VRT uses nearest resampling. You must specify something else.
> Look for "A resampling attribute can be specified" in
> https://gdal.org/drivers/raster/vrt.html
Actually in the provided .vrt file I can see
<SimpleSource resample="bilinear">
But isn't bilinear unsuitable for upsampling and some more blurring method
might work better?
-Jukka Rahkonen-
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
