[gdal-dev] ogr2ogr question
matteo matteo.ghetta at gmail.com
Mon Dec 21 07:29:51 PST 2020
Hi all,
I'm really stuck on a ogr2ogr command.
I've a template.gpkg file with some tables and what I'm trying to do is
to overwrite some of these tables with some already existing views of a
PG database.
The tables and views have the same structure and geometry, basically I'm
trying to create a my_data.gpkg with the same tables of the
template.gpkg file, but overwriting some of these tables with the PG
view contents.
This is the ogr2ogr command I'm using, but nothing is happening (the
data.gpkg remains the same of template.gpkg).
ogr2ogr -f GPKG /home/matteo/Desktop/data.gpkg "PG:dbname='mydb'
host=myhost port=5432 user='myuser' password='xxxxx' sslmode=disable"
--config PG_USE_COPY YES -sql "SELECT * FROM "_003"."intap" " -overwrite
-progress
(the intap table should be overwritten with the content filtered by the
-sql statement: "_003"."intap" is the view of PG).
I search everywhere for a parameter that could solve this problem but I
didn't find any
Thanks for any help
Cheers
Matteo
