[gdal-dev] ogr2ogr PDF
snorimaps
snori at geovista.in
Tue Dec 29 07:22:25 PST 2020
Hi Paul
Did you manage to solve this issue, I'm also unable to output a dash pattern
to PDF, it's always a solid line no matter what pattern I choose.
I also found several other PDF styling options not working:
- dash patterns for Linestrings
- LABEL option for Linestrings
- angle (a:) option for Points, when {angle} needs to be read from feature
properties.
I would appreciate any help from anyone to make the above work, I have tried
everything. Gdal v3.1.4
Thanks
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
