[gdal-dev] exporting all tables from PG schema
matteo matteo.ghetta at gmail.com
Tue Dec 29 07:25:57 PST 2020
Hi all,
I'd like to export all the table of a PG schema to either GPKG or a
shapefiles.
In the schema I've a lot of non-spatial tables and with something like:
ogr2ogr -f GPKG output.gpkg "PG:dbname=mydb schemas=myschema user=myuser
password=mypws host=myhost" -progress
the output is generated but it only contains geometric tables. I
couldn't find a parameter to force the export of also non-spatial tables.
What I'd like to avoid is to loop on every single layer
Cheers and thanks
Matteo
