[gdal-dev] NetCDF and EASE-2
Even Rouault
even.rouault at spatialys.com
Mon Feb 3 10:45:10 PST 2020
On lundi 3 février 2020 17:36:45 CET Marsh, Chris wrote:
> Yup, forgot to enable netcdf. Sorry about that.
> Otherwise your directions worked perfectly, thank you very much!
> In terms of understanding, exactly, these steps for the next time:
> 0) How would I have known the data were transposed lon, lat?
gdalinfo NETCDF:"SD_20160901.nc":snd_upd
reporting
Warning 1: No UNIDATA NC_GLOBAL:Conventions attribute
and
metadata with the lat and lon variables was a hint
"ncdump SD_20160901.nc" showing "float snd_upd(lon, lat)" confirmed it
> 0b) How would I have known the spacing of the lat variable was not constant?
Computing differences on consecutive lat values in the ncdump output. But
gdalinfo with "--debug on" also reports "Longitude is not equally spaced" (it
is confused here because of the lon/lat inversion, so this must be understood
as the latitude...)
> 1) What is the motivation to tiling the output?
So that transposition of the array works fast.
> 3) I don't understand this step. Why is this referencing back the nc
> file?
Because previous steps have lost the georeferencing
Even
http://www.spatialys.com
