[gdal-dev] Stacking JP2 files
Júlio César D. M. Esquerdo
julio.esquerdo at embrapa.br
Tue Feb 11 13:15:33 PST 2020
Hello,
I'm using gdal_merge.py to stack a set of JP2 rasters with the following command line:
gdal_merge.py *jp2 -o output.jp2 -of JP2OpenJPEG -separate
It didn't work. I got the message: "Format driver JP2OpenJPEG does not support creation and piecewise writing".
The command works fine for GTiff rasters, but not with JP2 files.
Is it possible to stack very compressed JP2 files using GDAL?
Thanks,
Best Regards,
Julio Esquerdo
____________________________________________________________________________
Aviso de confidencialidade
Esta mensagem da Empresa Brasileira de Pesquisa Agropecuaria (Embrapa),
empresa publica federal regida pelo disposto na Lei Federal no. 5.851, de
7 de dezembro de 1972, e enviada exclusivamente a seu destinatario e pode
conter informacoes confidenciais, protegidas por sigilo profissional. Sua
utilizacao desautorizada e ilegal e sujeita o infrator as penas da lei. Se
voce a recebeu indevidamente, queira, por gentileza, reenvia-la ao
emitente, esclarecendo o equivoco.
Confidentiality note
This message from Empresa Brasileira de Pesquisa Agropecuaria (Embrapa),
a government company established under Brazilian law (5.851/72), is
directed exclusively to its addressee and may contain confidential data,
protected under professional secrecy rules. Its unauthorized use is
illegal and may subject the transgressor to the law's penalties. If you are
not the addressee, please send it back, elucidating the failure.
