[gdal-dev] Stacking JP2 files
Even Rouault
even.rouault at spatialys.com
Tue Feb 11 13:27:25 PST 2020
On mardi 11 février 2020 18:15:33 CET Júlio César D. M. Esquerdo wrote:
> Hello,
> I'm using gdal_merge.py to stack a set of JP2 rasters with the following
> command line:
> gdal_merge.py *jp2 -o output.jp2 -of JP2OpenJPEG -separate
> It didn't work. I got the message: "Format driver JP2OpenJPEG does not
> support creation and piecewise writing".
> The command works fine for GTiff rasters, but not with JP2 files.
> Is it possible to stack very compressed JP2 files using GDAL?
With gdal_merge.py you can't directly output to JPEG2000 since the output
format of gdal_merge.py must have random write capabilities, which isn't
compatible of JPEG2000. A solution would be to output to GeoTIFF and use
gdal_translate to convert the GeoTIFF to JPEG2000
Or isnstead of gdal_merge, can use gdalbuildvrt -separate to create a VRT
file, and use gdal_translate to convert it to JPEG2000. That will save you the
materialization of a GeoTIFF file
In theory it could be possible to stack several JPEG2000 files in a single one
without any loss, but you'd need to use specialized tools for that.
Even
http://www.spatialys.com
