[gdal-dev] gdalWarp generates a black image when I use the outputBounds option
gustavorsantos gustavo.r.santos9 at gmail.com
Mon Feb 17 11:51:29 PST 2020
I am converting the Tiles Map Service coordinates to the ESPG:3857
projection. I have pretty sure that the tiles coordinates are between the
master image's bounds. I use the command line gdalwarp using the -te flag
but I have the same output.
Sorry, but I am working with private data and I don't know where you can
find similar data.
Anyway, thanks!
Gustavo Santos
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
